Brakes problem
1994 Ford F350 Two Wheel Drive Automatic 90000 miles
I have a f350 dually diesel. the brake pedal goes to floor when engin is running. ok when motor is off. new master cylinder, bench bled, no leaks in system. full system bled three times, all brakes adjusted and in good condition. The shop i had the work done at has no idea.
Jun 22, 2010 at 4:03 AM
