Hi ,Im working on a ford f350 dually , I have a good brake pedal untill i start the truck then it goes to the floor , I have tried 5 master cylinders , 2 have been from ford , two brake boosters , 1from ford , not rebuilt ,new hoses , new calipers , new ford pads , new vacume pump , 25 points of vacumme, new rabs valve new rotors and drums , new rear wheel cylinders, rear brake hose , I have searched all over for leaks , no leaks , the problem is in the front brakes , I blocked the rears completly off , I have bleed about 4 gallons of brake fluid threw the system , nothing seems to help this truck , I am a mechanic , been to alot of different schools , but this one is beyond me , Ive also pinched the brake hoses to the front and the pedal feels fine , thought it was calipers so have put two diffrent sets on besides orginal , have plugged rear brakes completly off , acts like master cylinder but out of 5 and 2 new ford oem i cant see that . but i guese anything is possible , any advice would be appreciated . thanks Gary
Dec 10, 2007 at 11:01 AM
