1991 Ford F350 brakes shudder
1991 FORD F-350
220,000 MILES • V8 • 2WD • AUTOMATIC
QUIKRJ
when i apply the brakes moderatly to hard the rear brakes shudder or skip violently .someone told me it was normal a precaution so as to stop them from locking up. its a dually and it feels like the whole truck is breaking up when it happens
Feb 10, 2008 at 11:46 PM
MERLIN2021
  • 17,250 POSTS
Not a normal condition! Remove drums and inspect....any axle oil leaking?
Feb 10, 2008 at 11:48 PM
REYNOLDT
  • 12 POSTS
After your look into the brake shoes, you might check the rear wheel speed sensor located on the rear axle. True, this anti-lock is a safety precaution, but it just started, right? Something has changed... brake fluid leaking on the brake shoes can cause expansion of the lining which can cause lock up. Check behind the rubber caps on the wheel cylinders. Fluid often seeps but does not make it to the exterior wheel. Also, if any brake work has been done recently, remember to bleed the ABS modulator valve under the drivers side on the main frame rail. Do this first then the right rear... left rear... right front then left front...
Feb 23, 2008 at 12:15 PM
