1984 Ford F350 HARD COLD START
COOTER1949
  • 1984 FORD F-350
Engine Mechanical problem
1984 Ford F350 V8 Two Wheel Drive Manual 91K miles
HAVE 6.9 FORD ENGINE VERY HARD TO START AFTER SITTING FOR THREE OR FOUR HOURS ONCE AT STARTS IT WILLRUN GOOD AND START ALL DAY NO PROBLEM I HAVE REPLACED MANUAL FUEL PUMP GLOW PLUGS GLOWPLUG RELAY AND SENSOR ALL FUEL RETURN LINES ENGINE SMOKES BAD WHILE CRANKING BUT QUITS AFTER 30 SECONDS AFTER IT STARTS WOULD MY INJECTION PUMP BE BAD?ANY HELP WOULD BE APPRECIATED THANK YOU
Thursday, April 3rd, 2008 AT 10:07 PM
COOTER1949
POSTED ABOUT 3 HOURS AGO NO REPLY YET HAVE I NOT POSTED CORRECTLY?OR NOT GOING TO CORECT SECTION YO VIEW HAVE DONATED THANK YOU
Friday, April 4th, 2008 AT 12:23 AM
2CARPRO JACK
  • 11,533 POSTS
More likely an injector problem. If there is a diesel shop in your area, they will be able to test the injector pump for you to be sure it is in spec. Does it run rough when it finally does start?
Friday, April 4th, 2008 AT 10:11 AM
COOTER1949
Thank you for the info. But found out all 8 new glow plugs that were instaled were bad got problem fixed
thank you
Sunday, April 6th, 2008 AT 2:51 PM
