1990 Ford F-250 Plastic Fuel Line Fix
DOUGS
I have a 90 model ford f 250 with a 5.8 engine, its has duel gas tanks also . My question is can i repalce the plastic fuel line on it with the rubber fuel line , the plasctic line broke an i'm haveing a hard time finding a replacement line
Oct 17, 2007 at 2:25 PM
BLACKOP555
  • 10,386 POSTS
yes you can as long as the fittings connect without leaking
Oct 17, 2007 at 2:45 PM
Suggested Repair
Rubber fuel line can replace the broken plastic line if the fittings connect without leaking.
Conversation Summary
The owner of a 1990 Ford F-250 with a 5.8 engine and dual gas tanks asked whether a broken plastic fuel line can be replaced with rubber fuel line. The expert said yes, as long as the fittings connect without leaking.
