1999 Ford F-250 Parking Brake Won't Hold Fix
KGB
TRUCK 1999 F250 SUPERDUTY 4X4 4 WHEEL DISC BRAKES.
HOW DO YOU AJUST EMERGENCY BRAKE SO TRUCK DOES NOT MOVE.
I CAN DRIVE WITH BRAKE ON AND WARNING SIGNAL SOME TIMES DOES NOT COME ON AT ALL.
THANK YOU; KEVIN
Oct 19, 2007 at 1:32 PM
BLACKOP555
  • 10,386 POSTS
under the vehicle follow the cable from the parking brake you should come to a splice where hte one cable goes to two with a bolt on it tighten that till you get your proper stopping.
Oct 19, 2007 at 1:48 PM
Suggested Repair
Under the vehicle, follow the parking-brake cable to the splice where one cable splits into two and a bolt is present. Tighten that adjuster until the parking brake holds the truck properly.
Conversation Summary
The owner of a 1999 Ford F-250 Super Duty with four-wheel disc brakes asked how to adjust the emergency brake so the truck would not move, noting it could be driven with the brake applied and the warning light sometimes did not come on. The expert advised following the parking-brake cable under the vehicle to the cable splice and tightening the bolt there until the brake provides proper stopping.
