1997 Ford F-250 Front Rotor Hub Socket Fix
CGLASER
I'm replacing the rotors and pads on this truck. The Haynes manual I have makes it sound like the rotors should just come off easily. After getting the rotor loose from the flange on the hub I'm realizing that the hub DOES have to come off prior to the rotor coming off. I popped the manual lockout cover to find that there is not a retaing "nut" persay it looks like i'm going to need a special wrench to remove the hub to get the rotor off. Am I correct or is there a much easier way to remove the rotor? Thanks CGlaser
Sep 13, 2006 at 12:18 AM
  • 55,682 POSTS
You are correct, there is a special socket that is used for that job.
Sep 13, 2006 at 7:33 AM
NOS
  • 320 POSTS
make sure you look up in there real close some times they use a retaining wire to keep the nut from backing off if you been that wire it is a real drag. the socke is not like a usual socket it has rounded corners and i think it is a 2 1/4 in socket. i have to go to the shop tomorrow to look up some specs and i will look for sure on the socket so you can get the right one i bought mine in a set there is like 6 different ones.(NOS)
Sep 15, 2006 at 2:29 PM
Suggested Repair
Remove the front hub before the rotor. Check closely for a retaining wire that keeps the hub nut from backing off, then use a special rounded-corner hub socket (often sold in a multi-size set; possibly about 2-1/4 inch) to remove the nut and hub so the rotor can come off.
Conversation Summary
The owner replacing front rotors and pads on a 1997 Ford F-250 4WD found the rotor would not come off until the hub was removed and asked whether a special wrench was required. Experts confirmed a special rounded-corner socket is needed and advised checking for a retaining wire on the hub nut. One expert thought the socket might be about 2-1/4 inch and planned to verify the exact size.
