1996 Ford F250 fuel pump not working
SCHOOLBUS
I have a 1996 Ford F250 5.0 with 147,000 miles. When trying to start, the fuel pumps will not cut on and is not firing. I have replaced the module, crank sensor, ignition switch, distributor, and ECM. I have checked the pickup coil, coil, all fueses and relays, and have reset the relay switch for the fuel pumps. Do you know what else I can check for fix?
Dec 28, 2006 at 2:34 AM
SCHOOLBUS
problem resolved...THANKS BUNCH FOR NONE OF YOUR HELP!
Dec 28, 2006 at 10:53 AM
HEAVYDUTY
  • 60 POSTS
what did you find?
Dec 28, 2006 at 12:03 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:2fe118a4a4="schoolbus"]problem resolved...THANKS BUNCH FOR NONE OF YOUR HELP![/quote:2fe118a4a4]
Believe it or not, most of us work during the day. :? We aren't the fast food of auto repair, nor do we get paid unless a contibution is made- not that I have received anything yet :)
How much did YOU contribute? HAve you lost anything?
Glad to hear your up and running :)
Dec 28, 2006 at 1:08 PM
