1995 Ford F250 parking brake cables
1995 FORD F-250
167,000 MILES • 6 CYL • 2WD • AUTOMATIC
OLDDOZER
I am having a problem with the replacement of my parking brake cables on my F250 reg. cab full size box pickup. I did a complete brake job including new drums. Brake cables were frozen and I replaced them now when I try to put the cables into the holes where they belong they are 3 inches short of joining up to the front cable. When looking at the cables with the length there is it almost looks like I need to move the parking brake mounting bracket on the side of the frame ahead by about 2 inches to be able to join up to the front cable and still maintain the pre load on the parking brake.
Nov 4, 2008 at 2:18 PM
  • 31,937 POSTS
Hi there,
It sounds as if you have the wrong cable, did you check the length against the old cable carefully? I would go back and re check the length first.
Mark (mhpautos)
Nov 4, 2008 at 3:47 PM
OLDDOZER
[quote:2a62d4898c="mhpautos"]Hi there,
Mark (mhpautos)[/quote:2a62d4898c] I checked cables and they are the correct length. Problem is the preload system I had to make a jig to draw the cables forward. I used a extra long cloths line tightener one end has a regular single hook and the other end has a twin hook set up. Placed single hook into a hole in truck frame then place twin hook over the joining piece that has parking brake cables already attached. Tighten as you would tighten a cloths line untill the front cable will go into it's proper place then remove jig.You will need at least 10 inches of tightening ability.
Nov 5, 2008 at 3:03 PM
