HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-250
Brakes
Rotor
1995 Ford F-250 cylinder not getting spark
RNM97
MEMBER
1995 FORD F-250
V8
4WD
AUTOMATIC
999,999 MILES
Only #2 plug not getting spark
new cap, new rotor, new wires, and new plugs
Friday, March 13th, 2009 AT 5:00 PM
MECHANIC
Is this a distributor system or a direct ignition system?
Friday, March 13th, 2009 AT 6:29 PM
RNM97
MEMBER
Distributor that is whats got me baffeled. I installed new cap, rotor, and wires still no spark only on #2
Monday, March 16th, 2009 AT 10:59 AM
MECHANIC
If the coil is throwing out through out the firing sequence they should fire if the cap/rotor/wire/plug are good.
Monday, March 16th, 2009 AT 6:22 PM
Please
login
or
register
to post a reply.
Related Brake Rotor Content
2000 Ford F250 Brake Rotor
What Is The Minimum Width A Rear Rotor On 2000 Ford F250 Can Be Turned?
Asked by
jimmyal
2000
FORD F-250
VIDEO
How to Remove a Stuck Brake Rotor
Instructional repair video
GUIDE
Rotor Stuck on Hub/Axle
Much like a rear brake drum that gets stuck to the axle flange, a brake rotor is subject to the same type of problem due to the fresh metal on both the brake rotor and the...
1992 Ford F250 Font Rotor
I Cant Get The Right Front Rotor Off On 1992 Ford F250. It Has Manual Locking Hubs And The Repair Manual I Have Only Shows How To Get The...
Asked by
fordboy351
1 ANSWER
1992
FORD F-250
2006 Ford F250 Brake Rotor
Hello, I Have To Take Off My Rotors To Get Them Turned, In The Chiltons Manual, It Say's They Pull Off After You Take Off The Caliper And...
Asked by
prtymrty22
1 ANSWER
2006
FORD F-250
Replacing Breaks
I Am Thinking About Doing A Break Job Myself Of My 2003 F250 4 X 4. Every Thing I Read Says To Replace The Rotors If I Replace The Pads. The...
Asked by
leroyazlin
1 ANSWER
FORD F-250
2004 Ford F-250 Brake Pedal
So One Day My Brake Pedal Started Going To The Floor With No Resistance. At First I Still Had Brakes But Not Till The Very End Of The Travel...
Asked by
Jakem96
2004
FORD F-250
VIEW MORE
Brake Rotor Replacement
Brake Rotor Symptoms
