1993 Ford F-250 Won't start
ANITAKENT
  • 1993 FORD F-250
  • V8
  • 4WD
  • MANUAL
  • 181,000 MILES
My truck will crank but after sitting for more than 2 days it will not start without at least 30 minutes of cranking. After it does start it seem to start with no problems if I start it every day but if it sits for a couple of days I have to start the long process of starting it again. The fuel pump does seem to be working I have tried to prime the fuel pump by turning the key off and on several times and that seems to help but only a little.
Friday, February 19th, 2010 AT 12:28 PM
Check the fuel pressure if its within specs and also test the fuel pump relay and also the ignition switch
Friday, February 19th, 2010 AT 12:42 PM
ANITAKENT
If the fuel pump is working doesn't that mean the relay is good also?
Friday, February 19th, 2010 AT 1:08 PM
Could be an intermittent problem with the relay or the computer control of the relay-
Friday, February 19th, 2010 AT 1:46 PM
