1991 Ford F-250 won't start when warm
DAVIDEMMERSON
  • 1991 FORD F-250
  • V8
  • MANUAL
  • 178,000 MILES
My truck won't start after it is warmed up. I have checked the battery, alternator, replaced the starter. Otherwise it runs great, what may be a factor is the heat! I live in Arizona and we have been in the 110's for a couple months. Please help!
Friday, August 21st, 2009 AT 9:53 PM
  • 109,755 POSTS
Will the engine continue running or die after it gets warm? Has the engine temp seemed to be getting higher than normal? When it won't start, have you checked to see if you are getting spark and fuel to the engine?
Friday, August 21st, 2009 AT 11:29 PM
DAVIDEMMERSON
It will run when warm just not start, it can be push started and it runs just fine. Engine temp is normal. And yes it is getting gas and spark. It sounds like a drained battery but if I wait 30 minutes everything is fine.
Saturday, August 22nd, 2009 AT 1:46 PM
  • 109,755 POSTS
Have you had the starter checked when this happens. Something tells me the starter is getting too hot and drawing too many amps.
Saturday, August 22nd, 2009 AT 4:24 PM
