1972 Ford F-250 starting
SGT.STIFFY
  • 1972 FORD F-250
  • 6 CYL
  • 50,000 MILES
My truck wont start with the ignition but when I hit the starter cable to the battery it starts rite up and purrs.
Wednesday, October 13th, 2010 AT 1:38 PM
Double check the battery cables and its connections and at the starter relay side-
Wednesday, October 13th, 2010 AT 1:59 PM
SGT.STIFFY
  • 8 POSTS
It has new solinoid plugs wires battery cable point condensor voltage regulator and when I have the ignition in it when I turn the key to the on position it jus constantly turns over until I unhook the battery
Wednesday, October 13th, 2010 AT 2:22 PM
At the starter relay at the small terminal mark S -remove the wire before you turn the key to On-now turn it on and check for power on that wire-you should not have power -if so the ignition switch is defective
Wednesday, October 13th, 2010 AT 3:09 PM
