Truck won't start
ACAROLINAJOY
  • FORD F-150
1994 F150 Ford Truck (4.9 engine)
electricty is getting to switch, lights and all the appripriate dinging comes on when you turn the switch, but nothing else, no clicking of an attempt to turn the engine over. Just dead
What is wrong?
Saturday, November 24th, 2007 AT 7:34 AM
MERLIN2021
  • 17,250 POSTS
Check all battery connections and voltage, you want 12 volts across the terminals. If OK if you can get under and reach the starter, turn key on, cross the S and Batt Heavy wire with a screwdriver, will it start?
If yes starter solinoid is defective, replace the starter.
Saturday, November 24th, 2007 AT 7:44 AM
