1992 Ford Probe No Crank
FOURSTAR
hello; i have a 1992 Ford Probe with 150,000 miles...
I am not able to start it....had to have it towed home.
Just put in a new battery.....car wouldnt start, about a day later
When key is turned engine does not turn over,
no clicking sound, no fuel pump sound....
Someone mentioned some type of neutral lock mechanism....?????
Tried jumper cables....
Any ideas....???
Nov 28, 2006 at 8:20 AM
SFOUTS
I have the same problem on a '96 Thunderbird. It did this once before several months ago but has started since (the car got jarred and it started). I have been told I should check the neutral safety switch/relay. Where is it and what does it look like?
Nov 28, 2006 at 9:36 AM
BRUCE HUNT
  • 3,754 POSTS
Post #1 This does not sound like a safety cutoff switch, it sounds like a cable grounding and possible positive cable problem.
Post #2 Getting hit can cause the safety switch to the gas line to shutoff. The reset is often found in the trunk but is spelled out in the owners manual.
Nov 28, 2006 at 10:07 AM
Suggested Repair
Check the battery cables for a poor ground and a faulty positive cable. If the vehicle was jarred or hit, reset the inertia fuel shutoff switch, often in the trunk and described in the owner's manual. The expert did not treat this as a neutral safety switch problem.
Conversation Summary
A 1992 Ford Probe with about 150,000 miles would not crank after a new battery: no starter click and no fuel-pump sound, and jumper cables did not help. A second owner reported a similar issue on a 1996 Thunderbird that once started after the car was jarred, and asked about the neutral safety switch. The expert said the no-crank symptoms point to a grounding or positive battery cable problem rather than a safety cutoff, and noted that a jolt can trip the fuel-line inertia switch, which is often reset in the trunk per the owner's manual.
