1981 Ford F-150 Starter Stays Engaged
MBARGER
Ford F 150 Custom 1981 125,000
Starter and Fly Wheel stay engaged after engine starts;Replaced starter and got same results. How sensitive are the teeth on the fly wheel? I noticed some knics and small scrapes on the teeth where the starter motor mounts. Can I remove the starter again and file the teeth? Is there any other electronic or electrical components in that loop that may be the culprit? The relay switch & the small box on the left side wall underneath the relay switch are relatively new. The other bigger grey box mounted on the right hand side I guess is the "brain" and has not been touched. i don't want to keep hanging parts. What do you guys think?
Mar 12, 2006 at 7:54 AM
PEPPERMRJ
  • 1,158 POSTS
How did this all start?
Replaced the starter with what? New, yours rebuilt, a different rebuilt unit. Did you have any shims and did you replace them?
Is yours a solenoid type. If so I'd check the solenoid. Are the flywheel bolts tight?
Unlikely to have 2 bendix/starter drive bad in a row.
Good luck and let us know. :)
Mar 12, 2006 at 12:12 PM
MBARGER
Ford F150 Custom 1981 125,000
This all started every once in a while the starter stayed engaged & disengaging when postive cable wiggled or removed from the battery. Actually this is my second new starter fro Advanced Auto Parts. Yes it is a solenoid type. Really unsure about shims., Is that like the gasket or something different? Fly wheel bolts are tight.
Mar 12, 2006 at 9:52 PM
PEPPERMRJ
  • 1,158 POSTS
Shims are just spacers that adjust the contact between the starter gear and the ring gear. Not very common nowadays.
You say that the two gears will disengage if the battery cable is wiggled or disconnected?
You could have a bad ignition switch. If it does not spring back it will keep the starter gear engaged. How is the lock cylinder? Is it tight or sloppy and loose? If it does not spring back the ignition switch won't.
You could also have the battery cable touching the small terminal on the solenoid. This would not let the solenoid retract.
Good hunting. Let us know.
Mar 14, 2006 at 10:04 AM
Suggested Repair
Check the ignition switch and lock cylinder for failure to spring back, which can keep the starter engaged. Also inspect whether the battery cable is touching the small solenoid terminal and preventing the solenoid from retracting. Confirm starter-to-ring-gear alignment and any needed shims; filing the flywheel teeth is not the recommended first step.
Conversation Summary
The owner of a 1981 Ford F-150 reports that the starter stays engaged with the flywheel after the engine starts, even after a second new starter was installed. The problem began intermittently and the starter would disengage when the positive battery cable was wiggled or disconnected. Flywheel bolts are tight and there are minor nicks on the ring-gear teeth. The expert advised checking starter shims and alignment, the ignition switch and lock cylinder for poor spring-back, and possible battery-cable contact with the small solenoid terminal.
