1996 Ford Mustang Oil in Spark Plugs
KOURTEEB_1224
I own a 1996 Ford Mustang GT, it has about 150000 miles on it, it is a V8, and is a 4.6 L. It stated missing really bad so we were going to change out the spark plugs on the car. When we went to pull out the spark plugs the four on the drivers side had oil in them but the other four did not have oil in them. What could be causing the oil to leak?
Apr 10, 2007 at 2:30 PM
BACKYARDMECHANIC
  • 337 POSTS
The plugs have oil on them due to poor oil control which is caused by leaking rings or value guides. This is often common on motors with high mileage or motors not properly maintained. Using a hotter plug may temporarily relieve the problem, but the motor probably needs to be rebuilt.
Apr 11, 2007 at 1:34 AM
PEPPERMRJ
  • 1,158 POSTS
Was the oil on the exterior of the plug or the electrode? Poke a q-tip down the plug hole with the plugs in and see if it comes back oil soaked. Sometimes a valve cover leak will flood the spark plug holes. This will in turn cause misfires. Simple remedy is to replace the valve cover gasket.
Good luck and let us know. :)
peppermrj
Apr 11, 2007 at 7:53 AM
Suggested Repair
Determine whether oil is on the plug electrode or only in the plug well. If the well is flooded, replace the valve cover gasket. If the electrode is oily, suspect worn rings or valve guides; a hotter plug may help briefly, but a rebuild is likely needed.
Conversation Summary
A 1996 Ford Mustang GT 4.6L with about 150,000 miles was misfiring badly. Oil was found in the four driver-side spark plugs but not the passenger-side plugs. One expert attributed oil on the plugs to poor oil control from leaking rings or valve guides and said a hotter plug might help temporarily, though a rebuild is likely. Another expert asked whether the oil was on the exterior or electrode and suggested checking the plug wells, noting a leaking valve cover gasket can flood them and cause misfires; the remedy is to replace the gasket.
