1994 Ford F-150 Runs Rough After Empty Tank
SSETTLE
I drive a 1994 F150 extended cab truck. About 12 weeks ago I ran out of gas (I have 2 fuel tanks and I still ran out of gas :( ). Since then the truck has been running terribly and getting less than 10 mpg. It didn't get a lot before that but it was better than 9mpg and my boyfriend is just ranting about how I ruined the truck.
Here's what's wrong besides the low mpg:
1) It runs REALLY rough.
2) It had a problem starting but we changed: spark plugs, rotor & cap, plug wires, and fuel filter. 2 of the plugs were really fouled.
3) It seems now that it needs a new driveshaft support bearing.
4) It bogs bad when going uphill
He says that maybe the fuel injectors are clogged or that I've ruined them. He hasn't checked those yet because he can get to the top 4 but the lower 4 are under the whatever and he may need a gasket.
Did I really kill it that bad by running out of gas?
Thanks,
Suzanne
Jan 5, 2007 at 6:13 AM
BACKYARDMECHANIC
  • 337 POSTS
Dear Suzanne,
Unfortunately you probably did do some damage to the fuel system. Cars that have electric fuel pumps can be damaged just by running out of gas. As far as the injectors go you may have sucked up some dirt but nothing that a good fuel injector cleaner should fix. Most of the dirt is trapped by the filter. ( thank God) Since you already changed the filter you have eliminated the easiest and cheapest part. Since that didn't correct the problem then you need to test the output of the fuel pump with a pressure tester to see if the pump is operating properly. If the pressure is not within specs the pump needs to be replaced. If the pressure is good and the filter was replaced then you may have clogged the injectors. Hope this helps and Good luck :)
Jan 5, 2007 at 7:23 AM
Suggested Repair
Test fuel-pump pressure with a gauge. If pressure is out of specification, replace the pump. If pressure is good, the injectors may be clogged; a quality fuel-injector cleaner may clear dirt that passed the filter, which has already been replaced.
Conversation Summary
A 1994 Ford F-150 began running very rough, bogging uphill, and getting under 10 mpg after running out of gas. Spark plugs, cap, rotor, wires, and the fuel filter were replaced, with two plugs fouled. The expert said running dry can damage an electric fuel pump and advised a pressure test; if pressure is good, clogged injectors are the next concern and cleaner may help.
