2001 Ford E-150 Rough After Engine Wash
TRICKRK
  • 6 POSTS
2001 E150 4.6 is running rough, missing and hesitating after having the engine washed. Check engine light came on also.
Where do I go from here? Any help would be appreciated
Apr 29, 2007 at 1:04 PM
BLACKOP555
  • 10,386 POSTS
did u jus spray it down with a hose? if so you probably got the ignition system wet and it is shorting out let it dry out
Apr 29, 2007 at 1:47 PM
TRICKRK
  • 6 POSTS
yes with just a hose.
The only problem is this was over a week ago and it has not been driven since it was washed.
Apr 29, 2007 at 10:30 PM
MERLIN2021
  • 17,250 POSTS
Start unplugging sensor connectors and drying them out with compressed air.
Apr 30, 2007 at 12:52 AM
TRICKRK
  • 6 POSTS
Thanks for your suggestions.
I barrowed a buddies scan tool and found out it was miss firing on two cylnders.
I replaced the plugs and removed, cleaned and regreased all the coil boots and contacts.
Almost all of the coils had some ammount of corrosion on the main contact fin at the top. Obvious signs of moisture migrating into the coil boot.
I added a light ammount of dielectric grease to the fin contact after cleaning as well.
A poor design in my eyes as I am sure this is a continual issue with this COP set up on these vans.
I cleared the codes test drove it and it still had a misfire and hesitation.
I drove it around untill finally kicked a check engine light , then scanned it again to find another misfire code. This time I replaced the offending coil and now it runs like a champ.
The over educated engineers who design this crap should be forced to service it at least once before they sell it to us suckers.
No big deal ,nothing a few parts and a full day being a greasy, filthy contortionist wont cure.
Later
May 1, 2007 at 1:14 PM
Suggested Repair
Dry the ignition system and sensor connectors with compressed air after an engine wash. Clean and dielectric-grease coil-on-plug boots and contacts, replace spark plugs, clear codes, and replace any coil that still sets a misfire code.
Conversation Summary
A 2001 Ford E-150 4.6 ran rough, misfired, and hesitated with a check-engine light after the engine was washed with a hose. It had not been driven for over a week. Experts suggested moisture was shorting the ignition and advised drying sensor connectors with compressed air. The owner found misfires on two cylinders, replaced the plugs, and cleaned and regreased corroded coil boots and contacts. A remaining misfire was resolved by replacing the affected coil, after which the van ran normally.
