Engine runs rough?
DYERBLAK1
  • 1995 FORD F-150
  • V8
  • 4WD
  • 122,000 MILES
I have a truck that I purchased from a friend. When I drove it home it seemed to be running a little rough and sometimes when I put on the gas it acted odd. It didnt cough or hesitate it just seemed to not run smoothly. I would back off the gas and reapply and it would go but just not ok. I got home and replaced the wires and the plug and cap and rotor. It helped but I started it up and ran it for a sec then turned it off to just look at something. Then when I went back to run it again it wouldnt start. I turned it over and over and nothing. I rechecked what I touched when it was off and nothing. I tried again and it ran after I kept on it. I drove it around the block but it seems to be idling rough. Like it wants to die. Also the plugs smelled gassy.
Saturday, April 4th, 2009 AT 7:54 PM
Check your fuel pressure and then comeback with the readings we start here.
Tuesday, January 8th, 2019 AT 6:03 PM
DYERBLAK1
I am mechanically inclined but where to I hook it up at? Do I need to do before the fuel filter or does it matter just incase my filter is the problem.
DYERBLAK1
Pressure was at 31 or 32 psi. Depending on the marks between. Also I did your test on the fuel pressure regulator and that checked out. Now when I turn the key the pressure gauge goes up but not to the 30 range. And when I rev it up the gauge goes up 3 or 4 psi.
When you turn key to run the fuel pressure should be 35-45psi and engine running should read 28-45psi
Sounds like the fuel pump is weak
DYERBLAK1
Does it matter that I have a dual tank? What are the odds of both being weak? Is that common? It could be my gauge also. Since when I turn on the key the gauge doesnt move at all. And I tried it on my other newer vehicle and it has a new fuel pump and same results.
Check the available voltage on both fuel pumps connector-could be a voltage drop problem.
1995BEAST
  • 1995 FORD F-150
  • V8
  • 4WD
  • 122,000 MILES
I have a 5.8 engine. The distributor recently shorted out and had to be replaced. I also had a major tune up. The engine had never ran rough before this. It will run rough when cold and drop about 800 rpm every couple seconds. It seems worse during acceleration. My mechanic tested all of the cylinders and says everything is as it should. He ran a fuel injection cleaning. Problem still there. He says fuel pressure is good and all electrical is working. Could you please help
Tuesday, December 15th, 2020 AT 3:45 PM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
Sounds like engine misfire. If the plugs and wires are ok then its possible the distributor is faulty.
1995BEAST
The mechanic checked spark on all of the wires and plugs and said they are all firing. The computer is giving no trouble codes. The rough running seems to get better after about 15 minutes when the truck has really warmed up
MASTERTECHTIM
  • 4,750 POSTS
I hate to say I doubt your mechanic but it seems as though it has to be a igniton breakdown. He should be able to find the cylinder. Possibly a cracked spark plug by accident?
2CAROY9
  • 1994 FORD F-150
  • V8
  • 220,000 MILES
Went to work, ran smooth, but when I got off work, it ran rough. Could this be an issue with the valve push rod? If so, do you know aprox how much it cost to repair or is it something a novice can do? Thank you
BLACKOP555
  • 10,371 POSTS
If it was a pushrod the vehicle would really run bad and you woudl hear a ticking/klanking noise.
If it was the pushrod its very easy to replace.
Just take off valve cover, loosen rocker arm, rotate to side and pull out the pushrod.
Be a bit more descriptive if you want to know whats wrong.
GAZ1984
  • 1994 FORD F-150
  • 6 CYL
  • MANUAL
  • 300,000 MILES
Hello. My truck runs a bit rough on idle and hesitates and misses under load. Im in the process of checking ignition timing and have tried to locate a spout connector but no joy. The timing light shows its either way off or somethings wrong. How do I adjust the ignition timing? Ive checked the distibutor and rotor everything is relitivly new from previous owner.
GAZ1984
Well ive timed the ignition and replaced plugs cap rotor and checked leads. Cylindr 2 is not working. The plug is sooted and dry. Im thinking it may be an injector and hopefully not rings. The engine does not smoke at all.
Are injectors a common problem on these trucks?
COCKY
  • 1993 FORD F-150
Hello. I have a 1993 Ford F-150 4x4, Inline 6-cylinder engine, stick shift with 218,000 miles. The truck does have dual fuel tanks.
Symptoms: Smell gasoline, quits when started first time (unless I kick the accelerator quick a couple of times), rough idle, and "jumps" or surges when you drive her. The idle is so rough you can hear it when it is idling. Last, I smell exhaust (and smell like it at times when I get out of the truck).
My truck is at my mechanic and he has gone over it from front to rear; he set the timing, but when he set the timing correctly, the truck ran worse!
The truck has had a tune-up recently (plugs, wires, cap, rotor button, fuel fileter, PCV Valve, and air cleaner). Mechanic said that when he disconnected a "round switch on the motor block that controls the vacuum", it ran a little bit better, but the check engine light came on.
Any advice is helpful; my mechanic is very honest, but neither of us want to start replacing things without knowing what direction to head in. Thank you for any assistance!
PS: Don't know if this is helpful, but gauge for rear fuel tank began working intermittently when all these problems started (it had not worked for four years). Also, fuel goes from one tank to the other (Ford dealer alledgely fixed with a recall, but I am doubtful).
Tuesday, December 15th, 2020 AT 3:46 PM (Merged)
BLACKOP555
  • 10,371 POSTS
Sounds like your fuel pump may be going have it checked. And the gas being pumped into the other has a recall out I dont know if yours has a dual fuel tank selector valve which is a black cylinder located under the driver side door has 4 hoses coming to it and 2 leaving it. I just bypasted the front one since I never used it.
KAELANMCELROY
  • 1993 FORD F-150
  • 5.0L
  • V8
  • 4WD
  • 86,000 MILES
The truck has a good idle, but anywhere from 45mph up you have to the rpms above 1800 or it shakes violently. Its not wires or plugs and the motor mounts are fine. Also it will die when turning the wheel while in reverse.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure to make sure it is not a engine issue then have tires checked for balance as well as driveshaft ujoints.
KAELANMCELROY
No codes pull up, and its not the tires because it quits shaking when I let of the gas, also the ujoints are good
HMAC300
  • 48,601 POSTS
Just you let up on the gas doesn't mean the ujoints are any good if they have rust around the seals then they are shot or on their way. Does it have a vacuum leak? What is the fuel pressure measured by a gauge like I suggested in last reply. Not by it sprays cause you hit the Schrader valve. Were the wires and plugs replaced and are they in the correct firing order? Does it run rough while in park or neutral from idle up to say 3000 rpm? Is the front end in great shape and has been check professionally
