Raditor issue
LITHEON
  • FORD F-150
I have a 1990 ford f-150 2 wheel drive 5.0 v-8 with 116000 I had the anti-freeze replaced the water pump replaced and the thermostat and thru the recovery reservior it fills up with anti-freeze and overflows why is that and is it a good idea to replace the the raditor
Sunday, February 25th, 2007 AT 10:13 AM
SERVICE WRITER
  • 9,123 POSTS
The system may be overfull, there may be a restriction, or there may be a head gasket issue. Does it overheat?
Sunday, February 25th, 2007 AT 12:00 PM
LITHEON
No it doesnt oveheat the temp gauge stays in the normal range
Sunday, February 25th, 2007 AT 12:45 PM
SERVICE WRITER
  • 9,123 POSTS
It sounds like the system is just seeking it's level.
Sunday, February 25th, 2007 AT 3:01 PM
ADRIANTHOMSON
Buy something like rad weld you should be able to seal the leak and then clean all your pipes aswel
Sunday, February 25th, 2007 AT 5:26 PM
SERVICE WRITER
  • 9,123 POSTS
I must have missed the part about the rad leaking.?
Sunday, February 25th, 2007 AT 5:45 PM
LITHEON
I thought about a leak too but its not leaking I had my mechanic check it out when he flushed it out but when I look down in the raditor it looks like the is alot of rust and scale in it so would it be a good idea to replace the raditor
Sunday, February 25th, 2007 AT 6:30 PM
SERVICE WRITER
  • 9,123 POSTS
It won't hurt to replace, but If it isn't plugged or leaking, I wouldn't.
Sunday, February 25th, 2007 AT 6:35 PM
