I have a coolant leak that seems to be originating from the top rear part of the engine. Could this be a head gasket leak or is it something more intense?
Brad
Friday, December 7th, 2007 AT 5:59 PM
BLACKOP555
MECHANIC
Have you noticed white exhaust with the smell of antifreeze? If so you have a bad head gasket. You may also have a cracked or warped head due to overheating.
Friday, December 7th, 2007 AT 6:15 PM
KEN L
MASTER CERTIFIED MECHANIC
I have seen the thermostat housing leak and the intake manifold as well. You need to use a flashlight while the cooling system is under pressure. These guides can help you find the leak.
