1997 Ford F-150 Parking Brake Light
SONNYFORD
I have a 97 f150 with 47000 miles 4x4 8 cyl. and I can not get the brake light to go off. I was using the parking brake while I was removing the tires and than working on adjusting the rear brake pads using the adjustment wheel. When I finished the adjustment the light will not go out. it appears to drive ok . I just think it could be the switch for the brake is not showing it is released.
Sep 23, 2007 at 10:44 AM
MERLIN2021
  • 17,250 POSTS
Could be the cables ar sticking, try to pull up on the parking brake pedal, if the light goes out, drive to a slight hill go to the top of the hill put the truck in neutral, does it roll easily? This is to make sure the parking brake is not stuck on! As a matter of course with brakes it's use it or lose it!
Sep 23, 2007 at 10:47 AM
Suggested Repair
Check for sticking parking brake cables. Pull up on the parking brake pedal to see if the light goes out, then on a slight hill put the truck in neutral and confirm it rolls freely so the parking brake is not stuck applied.
Conversation Summary
The owner of a 1997 Ford F-150 says the parking brake light stays on after using the parking brake while adjusting the rear brakes. The truck appears to drive normally. The expert suggests the cables may be sticking and recommends pulling up on the pedal to see if the light goes out, then testing on a slight hill in neutral to confirm the parking brake is fully released.
