Overdrive is not working?
NLG
  • FORD F-150
My overdrive is not working in my 01 v8 4.6 l ford f-150. Could it be something simple?
The transmission is shifting fine (not "hard shifting), when I try and turn the overdrive on or off the control switch does nothing (does not light up). Is just something with the control switch? Or a sensor? Ever since the control switch stopped working I began using more fuel (i believe it is not going into 5th gear).
Monday, April 9th, 2007 AT 11:03 PM
DV_SHANE
Check all the connecters that plug in to tranny see if one had came loose and check fuses I doubt its a fuse if its not a plug the solinoid for overdrive is inside the pan on valvebody 2 shift sol. 1 sol for o.D.(Toc)
Tuesday, April 10th, 2007 AT 9:10 PM
