Im having the same problem with my car. So far I have changed thermostat, flushed radiator, but I put too much antifreeze in it. So, now I have about 1/2 to 3/4 gal. Antifreeze and the rest water. Made sure the vent is closing so you dont get no outside air, radiator has 2 pin holes so I will replace it next and I put a piece of cardboard in front of the radiator and that helped alot mind boggling huh! Well good luck! You know you might look and see if there is a fuse for the heater either under the hood or under the dash.
SPONSORED LINKS
Friday, January 20th, 2006 AT 1:50 PM
