having troubles starting
FRENCHY6699
Im having troubles starting my truck its a 1996 F-150,for awhile it would start no problem but then one day i drove it all day shut it off then went to start it again and it wouldnt start, so i had to boost it and its been like that for awhile now itll run then i shut it off and then it wont start. Now i cant even boost it. Does that sound like the starter and if so where is the starter located on these trucks.
Nov 20, 2007 at 5:45 AM
  • 75,988 POSTS
Check the battery connections and at the starter make sure its clean/tight. This checks out might want to have the alternator and battery tested to include the starter relay/solenoid. Could also be the TRS or the Ignition switch.
Nov 20, 2007 at 7:20 AM
