2000 Ford F-150 Fuel Pressure Loss
LOFASHO00
How you doing i'm having a fuel issue with my truck. I have a 2000 ford f-150 4.6L V8 2WD. It has 87,000miles on it. The truck is a custom truck. I had an air ride system put in the truck for shows. The truck was body dropped 4 inches and bagged. So the truck lays out on the ground with frame. So by doing this i had the gas tank relocated to behind the axle. Well come to find out the person who moved the gas tank swapped the gas tank out with a 2000 chevy blazer gas tank. Well as far as i know chevy doesnt make over a V6 engine. Now my fuel gauge doesnt work. No big deal i can deal with out it. But the truck is have running problems. I replaced spark plugs just dropped a new tranny in it with new clutch. When idle the truck runs fine the moment i put my foot to the gas the truck loses power and will jump back and fourth. I replaced the fuel filter ad well. The only thing i can think of is the engine isnt getting the right amount of fuel. I plug a code reader in and it spit 3 codes. One was the engine was running too lean. 2&3 where cylinders 2&3 were missfiring. Could my problem be that the fuel pump isnt pushing the right amount of fuel and if so do you know what PSI a stock ford fuel pump runs at? I plain on putting a 20gallon aluiminum fuel cell in i just need to find an external fuel pump bt i dont know what a stock ford fuel pump runs at to know which one to buy. Any help would be great. Thanks
Jan 21, 2007 at 2:49 PM
SERVICE WRITER
  • 9,123 POSTS
The spec for yours is 30-45 psi, with the KEy On Engine Off. Ford doesn't specify the KOER spec. NAturally, The Chevy listing appear to be the opposite :?
Jan 21, 2007 at 9:08 PM
SERVICE WRITER
  • 9,123 POSTS
Chevy s10 blaze 4.3- 60-66psi KOEO
Chevy V8 C1500 4.8 & 5.3- 55-62 psi KOEO
Che s10 2.2 -41-47 psi KOER
Jan 22, 2007 at 9:12 AM
Suggested Repair
Verify fuel pressure against the Ford specification of 30-45 psi with the key on and engine off. The swapped Chevy Blazer tank and pump may not match that pressure, so choose an external pump for the planned fuel cell that supplies about 30-45 psi KOEO.
Conversation Summary
The owner of a 2000 Ford F-150 4.6 reports power loss and surging under throttle, a lean code, and misfires on cylinders 2 and 3 after the fuel tank was relocated and replaced with a 2000 Chevy Blazer tank. The fuel gauge also does not work. The expert states the Ford fuel-pressure specification is 30-45 psi key-on, engine-off, and notes that listed Chevy pump pressures are generally higher.
