2001 Ford F-150 DPFE High Voltage
TOMPRE
I have a 2001 F 150 with a 4.6 engine,I had a OBD test run on it and the code showed DPFE circuit high voltage.So I bought a new DPFE sensor but when I went to put it on there wasn'one.The bracket was there but not the sensor.There were no lines to hook to the sensor either.What do I do?
Aug 3, 2007 at 10:50 AM
SERVICE WRITER
  • 9,123 POSTS
Yikes!!! Post some pics that we can maybe do some comparisons with. We have a couple of retarded Ford guys here that may help out quick. I can't wait til I'm retarded so I can spend all day on the Net :D !
Aug 3, 2007 at 12:24 PM
SKIBO1
  • 7 POSTS
there are two types of dpfe sensors, if the bracket is there but nothing else, that means you bought the big sensor but you need the small sensor. the small type is a little black square sensor just to the left of the brake booster and stuck into two hoses that go to the manifold for the egr. likely you just need to go back and get the correct part
Oct 24, 2007 at 5:46 AM
Suggested Repair
Return the larger DPFE sensor and get the small black square type. It sits just left of the brake booster and plugs into two hoses that run to the EGR manifold.
Conversation Summary
The owner of a 2001 Ford F-150 4.6 got a DPFE circuit high voltage code, bought a DPFE sensor, and found only a bracket with no sensor or lines. A reply explained there are two sensor types and that the correct part is the small black square sensor left of the brake booster, connected to two EGR hoses.
