1991 Ford F-150 Rich Miss
Don't rely exclusively on the computer though. Being a '91, the computer won't pick up on what's about to fail, only what already has. So you could have a sensor or a solenoid way out of whack and the computer wouldn't know it. I hope this helps.
Possibly in this case, being able to scan the computer for fault codes will give you the clue you need to narrow down the problem. Since it's starts to perform poorly when the check engine light comes on, (that indicates fault code(s) was set) that would be an emission component related problem.
Suggested Repair
Replace the fuel pressure regulator. The owner confirmed that a faulty regulator caused the rich running, miss, unstable idle, and poor fuel economy. Also scan for codes and verify fuel pressure, spark timing, and compression.
Conversation Summary
A 1991 Ford F-150 with a 302 engine idled poorly, missed, surged or nearly stalled when the clutch was pressed, and used excessive fuel while running very rich. Plugs, wires, cap, rotor, fuel filter, and the idle control motor had already been replaced, and fuel pressure was good. The expert advised scanning for codes once the check engine light came on, then checking fuel delivery, spark timing, and compression, and noted a stuck injector or emissions fault could cause similar symptoms. The owner later reported the fuel pressure regulator was the cause.
