1977 Ford F-150 Engine Dies While Running
DWILSON
1977 F-150 4X4 300 6-cylinder Inline 4 Speed on floor 118,000 miles Original Owner
After starting my truck and driving a short distance, the engine just dies. It starts right back up and it may do this once or twice and then runs perfectly. I have changed out fuel filter,spark plugs,plug wires,rotor and distributor cap. What can be causing it to just die and what should I check and do next to fix the problem . Thanks for your help
Dennis Wilson
Jun 24, 2007 at 1:51 AM
MERLIN2021
  • 17,250 POSTS
Check bothe the choke thermostat, and the ignition module....Fords back then were known for going thru modules!
Jun 24, 2007 at 1:53 AM
Suggested Repair
Check the choke thermostat and the ignition module, which commonly failed on Fords of this era.
Conversation Summary
A 1977 Ford F-150 with a 300 inline-six dies after a short drive, restarts immediately, and then usually runs normally. The owner already replaced the fuel filter, spark plugs, plug wires, rotor, and distributor cap. The expert recommends checking the choke thermostat and the ignition module.
