1999 Ford F-150 Exhaust Rattle and Smoke
Suggested Repair
Inspect the catalytic converter heat shield; if the mounts are rusted and the shield is rattling, secure it tightly against the converter with extra-long hose clamps. For occasional light tailpipe smoke, start with a compression test, noting how pressure builds on successive cranks, and wet-test any low cylinders with a small amount of oil to help distinguish worn rings from valve seals or guides.
Conversation Summary
The owner of a 1999 Ford F-150 with 257,000 miles reports an underbody rattle that a mechanic attributed to the catalytic converter, plus occasional light tailpipe smoke, and asks whether the issues are related or the truck should be replaced. The expert says a rusted heat shield can rattle and can be clamped tightly to the converter. The smoke may come from worn valve seals, guides, or rings, so a compression test and wet test of low cylinders are recommended first.
