Air conditioning problem
DCAMERON
  • FORD F-150
2003 F-150 Lariat with about 70,000 miles and V-8 engine. Started with Max AC suddenly diverting to defrosting vents but panel/floor still worked properly. Now all cooling options divert to defrosting vents and will not function through the main vents. Water or condensation of some sort is leaking from tail pipe after long drives.
Monday, September 3rd, 2007 AT 4:57 AM
MERLIN2021
  • 17,250 POSTS
You have a vacuum leak, and when there isn't enough vac to operate the servo's they rest in the defrost position, the "condensation" from tailpipe is normal!
Monday, September 3rd, 2007 AT 7:15 AM
