Ford F-150 ABS Speed Sensor Test
CHAMP7
  • 6 POSTS
I wanted to know if you can test a speed sensor with a volt meter by measuring ohms. Would like to save a trip to the dealer where I know they charge $55 just for test. Thanks Steve
Oct 1, 2007 at 7:43 AM
MERLIN2021
  • 17,250 POSTS
Yes! Place it on ohms, probe the connector, should read 800-1400 ohms. Did you reitrieve the ABS code(s)?
Oct 1, 2007 at 8:44 AM
CHAMP7
  • 6 POSTS
Thanks for ohms reading I will check tuesday and post update of how I made out.Thanks
https://images.2carpros.com/forum/automotive_pictures/103332_DSCF0006_2.jpg
Oct 1, 2007 at 11:12 AM
Suggested Repair
Test the ABS speed sensor with a multimeter set to ohms by probing the connector. A normal reading is about 800-1400 ohms. Also retrieve any ABS codes.
Conversation Summary
The owner of a Ford F-150 asked whether an ABS speed sensor can be tested with a voltmeter by measuring resistance to avoid a dealer diagnostic fee. The expert said yes: set the meter to ohms, probe the connector, and expect about 800-1400 ohms, and asked whether ABS codes had been retrieved. The owner planned to check and update later.
