Please can someone help? Where is the abs control moduel located on a 2000 f150 and how do you remove it.
Apr 17, 2007 at 8:12 AM
The ABS control module is the box with electrical connectors and brake lines, located beneath the air cleaner. Replace the master cylinder, all brake lines, and the module together as one unit.
The owner of a 2000 Ford F-150 asked where the ABS control module is located and how to remove it. The expert identified it as the box with electrical connectors and brake lines and recommended replacing the master cylinder, lines, and module as one unit. The owner later found the module beneath the air cleaner.
