86 Ford F-150 300
CASEY1983
  • 1986 FORD F-150
Hi my ford F-150 4.9 L. Well it runs for a sec(5 min. Maybe) then RPM's drop then kick back up, well it does that a few times then it dies and cant get it started again for about 10-20 minutes.I've replaced--ignition control module---alternator(voltage regulator)---rebuilt the carb.---Coil---replaced fuses--fuel filter---fuel pump--checked for clogs in the fuel lines---I think thats it maybe one or two other things but if you could help me I'd be extatic.I think it has something to do with the electronic ignition but I don't know what thanks. Oh it's a stick
Monday, November 26th, 2007 AT 11:22 PM
MANGANNON
Is this a carb or fuel Injection?
Wednesday, November 28th, 2007 AT 1:34 AM
IMNOTLOKIN
  • 11 POSTS
He is a quick check that Iv'e done. Have you check the fuel preesure coming form the fuel pump? Disconnect the fuel line at the carb, crank the engine over, and see how much fuel come out. (Use clean catch container) If the container rills up quickly, the pumps working. Hook everything back up and check to see if the carb squirts fuel into the carb by moving the linkage. If it does, try to start you r vehicle. If it doesn't start, pour a few ounces of fuel in the carb and try to start. If it does, you have a igntion/distributor problem. The TFI module (on the distibutor) you say was replaced, check your wiring for good connections. Hope this helps.
Thursday, November 29th, 2007 AT 6:02 PM
