2005 Ford F-150 Trouble Starting
DAVID 6363
  • 2005 FORD F-150
  • 6 CYL
  • 102,000 MILES
This problem happened about a month ago, yesterday and this morning. As I turn the key to start the pickup the starter turned over for just a second then stopped. The power to everything is cust for a second because the radio and clock has to be reset. Whe I turn the key the second time the pickup starts up. I'm in south Texas so the temperature is humid and atou 50 degrees when this happens.
Tuesday, February 23rd, 2010 AT 10:33 AM
  • 110,182 POSTS
Chances are you have a bad connection at the battery. What I recommend is removing the battery terminals and cleaning them and make sure they are tight when you replace them.
Friday, February 26th, 2010 AT 1:55 PM
