I have a leak on the Exhaust output manifold gasket.
My pipe seems to be bent a little. CAN A fellow geta some kind of a sealant to block of the Leak?
Wednesday, October 29th, 2008 AT 8:43 PM
DLOBI
MEMBER
Any sealant put on from the outside would likely get burned off and pushed out by the pressure.
If the exaust manifold gasket is leaking, the fix is a new gasket installed.
