2003 Ford F-150 Won't Start
F150 2003
  • 2003 FORD F-150
Engine Mechanical problem
2003 Ford F150 V8 Two Wheel Drive Automatic
My Truck will not start fuel pump works changed fuel fiter. The other night my truck was acting like it was not getting power. I stop at a stop sign and it just shut off I tried to start it and it did and then went right back off and then it would not start at all. So l waited over night truck started right up and sputter off. Now I have changed the fuel fiter and checked that the fuel pump works and I have a sprak on my pugs. What do I do now.
Saturday, September 12th, 2009 AT 11:46 PM
GFOSTER1989
The problem could be your alternator, usually a good battery will recharge itself and that could be why your truck started back up, some hints that it would be the alternator would be if the gauges acted funny, slowly lost different electronics or lights dimming. Have you tried jump starting it at all?
Sunday, September 13th, 2009 AT 12:11 AM
F150 2003
Yes tried that truck will turn over but will not start only if it sits over night will it start and right back off. And then nothing.
Sunday, September 13th, 2009 AT 12:19 AM
GFOSTER1989
Sorry I cant help you there then because I have a 1989 with a similar problem
Sunday, September 13th, 2009 AT 12:23 AM
F150 2003
I put my tester on my truck and a code popped up P1633 INC =Catlyst -O2 - 02Hrt - EVAP - EGR READY= Misfire - FUEL - Comp. I know the incomplete is because it will not start but I had a friend with a 2009 GMC truck trie to jump me off it trun over and trie to start but would not any ideals.
Sunday, September 13th, 2009 AT 1:27 PM
