2002 Ford F-150 SPUTTERING THEN SHUTS OFF FOR AWHILE
TONYBBABY
MEMBER
2002 FORD F-150
V8
2WD
AUTOMATIC
18,000 MILES
The truck will run for awhile then I turn it off then it wont start but if it does start it acts like its not getting gas. I changed the fuel filter and spark plugs. Also when im driving it sputters then shuts off. I put injector clean in the gas. Still not helping. It shut down yesterday and wouldnt start back up but it did this morning. Somebody help
SPONSORED LINKS
Wednesday, September 22nd, 2010 AT 10:20 AM
MECHANIC
Have you checked fuel pump pressure? Also, when it doesn't start, can you hear the fuel pump run for a second or two when you first turn the key on?
Wednesday, September 22nd, 2010 AT 1:14 PM
TONYBBABY
MEMBER
Im ingnorant when it comes to cars. How do you check fuel pump pressure?
And how can you tell if its working?
Should I just get a new pump
SPONSORED LINKS
Wednesday, September 22nd, 2010 AT 9:24 PM
MECHANIC
Hi:
I'm sorry about the delay in getting back to you. I lost my father this week and I'm sure you understand.
As far as checking fuel pressure, here is a how to. You will need a pressure gauge. Most parts stores will lend or rent them.
