2001 Ford F150 vribration
2001 FORD F-150
185,000 MILES • V8 • 4WD • AUTOMATIC
LLOYDDENNY
My truck vribrates or pluses when breaking. I thought it was the front rotors or break pads but have installed new rotor and pads, it seems maybe a tiny bit better but that didn't fix it. Any Ideas? The steering seems tight, it tracks true and doesn't drift or have play in the steering. Could it be ball joints? Thanks for any help you are able to provide.
Aug 14, 2009 at 4:37 PM
DA_FORD_MAN
Well if it is like a catching/releasing feel when you hit the breaks, I would check all the break lines for any pinhole leaks and then bleed the break lines. If that doesn't fix the problem, then you might have trash in the system. Hope it helps.
Aug 20, 2009 at 4:17 AM
