2001 Ford F150 High Speed Vibration
102,000 MILES • V8 • 2WD • AUTOMATIC
DMZ40
Slight vibration increases as speed increases. At 60 mph it vibrates violently. I shift into neutral and vibration is still there. So, not the engine, right? Based on the mileage, I replaced lower ball joints, upper control arms(with ball joints), rotors, brake pads, wheel bearings and shocks. Symptoms still occurring. What else should I consider? And how do I test for...?
Dec 8, 2007 at 7:08 AM
JWALTH02
  • 180 POSTS
Rear wheels? Check the driveshaft, u-joints and bolts. Also could need balancing for the tires.
Dec 8, 2007 at 12:52 PM
  • 55,658 POSTS
Yep, I have seen water inside one of the tires do this as well, I would have all four tires balanced. This guide can help as well
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Please go over this guide and get back to us.
Jul 22, 2024 at 7:11 AM
