2001 Ford F150 Turn light and break light
2001 FORD F-150
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
LARRY1113
my drivers side turn light and break light do not work -- the tail light does, i have switch bulbs and i have switch the bulb holders and it still dose not work-- any suggestions?
Mar 7, 2010 at 2:45 AM
CJ MEDEVAC
  • 11,004 POSTS
POSSIBLE HELP ??!!--------See my profile--------
INSURE your bulbs (all that may be involved) are all the way in..... CORRECTLY!!!! (NOT just jammed in any old way)-------
If NO-GO-------run temporary jumper from NEG GRD BATT to............... housing/ NEG on wire/ to bulb/ touch GRD screws/ etc. that grounds that system---IN ESSENCE YOU ARE GIVING THE SYSTEM A GROUND IT HAS LOST.
TOUCH ONLY-ONLY-ONLY GROUNDS (or you will SHORT SOMETHING....BLOW FUSES...OTHER BAD STUFF MIGHT RESULT !!!)......If one of these operations makes it work........Repair that problem (the faulty ground).......Like I said, "POSSIBLE HELP" .........Maybe a switch etc.
Love, Turddog
Mar 7, 2010 at 9:07 AM
