2001 Ford F-150 fuel problem
LIMIT
  • 2001 FORD F-150
Engine Mechanical problem
2001 Ford F150 6 cyl Four Wheel Drive Automatic
my engine isnt getting fuel delivered to it.I changed the fuel pump n fuel filter no luck. When I let it sit for a day it gets a little gas then when I try to start it the fuel goes away.
Friday, January 23rd, 2009 AT 11:47 AM
BASTINH
  • 8 POSTS
I would check the fuel pressure regulator. Its very possible that it could defective.
Friday, January 23rd, 2009 AT 12:12 PM
LIMIT
I checked the fuel switch and its okay.I think it might be fuel pressure regulator or the camshaft position sensor. Can anyone tell me where the camshaft position sensor is located at or give me any options on to what is causing the problem
Friday, January 23rd, 2009 AT 3:29 PM
LIMIT
Someone plz help
Monday, January 26th, 2009 AT 3:17 PM
