My 2001 f150 will crank but when I try to give it gas is starts sputtering and dies. Then it won't crank again for a while. I changed fuel filter, checked fuel pump, checked coil. Fuel pump pumping strong and coil has correct resistance. Could this be caused by cam sensor or crank sensor or do I need to start somewhere else?
SPONSORED LINKS
Thursday, October 30th, 2008 AT 7:53 PM
