2001 Ford F150
78,000 MILES • V8 • 4WD • AUTOMATIC
DAN LINDER
after the vehicle has heated up, there is a distinct rubbing/grinding noise coming from the front end. brakes have been replaced, noise continues. been in shop(not ford) 4 times, unable to analyse. latest suggestion is bearing in front transmission. has there been a factory bulletin on this problem? any suggestions
Jul 20, 2009 at 5:31 AM
BUDDYCRAIGG
  • 2,262 POSTS
does the truck have to be in motion for you to hear the sound?
does the sound change at all if you slightly apply the brakes?
Jul 20, 2009 at 2:13 PM
DAN LINDER
yes, the car needs to be in motion, making a turn at slow speed, left or right, forward or reverse.
use of brakes has no impact.
Jul 21, 2009 at 2:16 AM
BUDDYCRAIGG
  • 2,262 POSTS
Do you have any buddies, that you could talk in to hanging on to the frame while you take it for a test drive?
Okay, bad idea.
Call around to some of the larger shop, probably dealers. To see if they have what we call "miracle ears"
It's a device with 6 (sometimes 8 or 10) microphones that you can attach to different parts of the car. And you wear headphones and turn on and off each mic. when you get to the one that is the loudest, then you know you have that mic closest to where the problem is.
Jul 21, 2009 at 3:21 AM
