The check engine light is on. The code is that it is running to lean.
Have checked the spark and its good, haven't checked the TPS, how do you do that?
It idles really high then after driving it was start to idle up and down at stops. Then after long periods of driving when I push the gas after stops it will idle up and down and run slugish and barely moves at firstthen picks up. Then a little after that it will start to die at stops and then when driving normal it starts to run rough when pushing the gas. But when it dies and I start it up it will take off fine. Then do it agian at the next stop.
Also after it sets for 30 min or so it will run ok. It seams longer it cools off the longer it takes for it to start messing up.
Thursday, August 27th, 2009 AT 6:58 PM
