2000 Ford F-150 trouble starting
PETERM
  • 2000 FORD F-150
  • V8
  • 4WD
  • 12,500 MILES
Hi all,
I have a Ford F-150 that I have had a bit of difficulty starting lately! Battery is reading 12 volts but truck won't start. But I can boost it and it starts! A friend has suggested that it might be a bad ground. How would I go about testing his theory? Are there other possible scenarios?
Tuesday, August 18th, 2009 AT 12:18 PM
Load test the battery if okay- clean and properly tightened both ends of the battery cables.
Tuesday, August 18th, 2009 AT 2:50 PM
BAMBAM302
  • 5 POSTS
I've had the same problem before and it was the battery cables themselves. They looked fine until I cut into one halfway down and it was green corrosion on both hot and ground. Replaced them and had no more problems.
Thursday, March 15th, 2018 AT 5:37 PM
MIKE H R
  • 3,094 POSTS
A little corrosive in the cables will mess up everything.
Saturday, March 17th, 2018 AT 1:47 PM
