2000 Ford F-150 starter will crank normaly wen cold and not
MATIAS150
  • 2000 FORD F-150
  • 4 CYL
  • 310,000 MILES
I wet every thing with a wather howse from the top of engine and nothing hapen but wen I wet from under the frame all exost pipes and catalitic converter, probably starter too, estart imediately, starter seems to work perfect wen works.
is the starter cables?
is the computer cuting power to starter?
Wednesday, August 18th, 2010 AT 12:00 PM
  • 110,182 POSTS
You may have a bad starter. What you need to do is have a helper turn the key to the start position while you check to see if the starter is getting power. Do this when it doesn't work. If you are getting power, then the starter is bad.
Wednesday, August 18th, 2010 AT 7:58 PM
