As soon as vehicle is started, remove the signal wire from the starter solenoid, does vehicle still attempt to start/ if so then either the solenoid is sticking or the starter has failed.
If it does shut off the starter right away there is a issue with the ignition switch.
SPONSORED LINKS
Sunday, February 15th, 2009 AT 8:42 AM
