1999 Ford F-150 noise
DRGONZO442
  • 1999 FORD F-150
  • V8
  • 13,400 MILES
Truck seems to loose oil pressure out of the blue before it looses oil pressure runs perfect then oil pressure just drops.                         Thanks
Friday, January 23rd, 2009 AT 5:41 PM
  • 109,951 POSTS
Hi:
When you loose pressure, does the engine make noises like knocking, tapping.
Friday, January 23rd, 2009 AT 7:48 PM
DRGONZO442
Hi, yes it does start to make what sounds like the engine not circulating oil when pressure drops, then engine gets pressure back and engine quiets right down. Any possibility that a timing chain tensioner going out, or oil slug build up. Was going to flush oil and put hi mileage oil in.
I believe vehicle sat for a month. Thanks again
Saturday, January 24th, 2009 AT 12:02 AM
  • 109,951 POSTS
Hi:
This doesn't have anything to do with those things. If it was me, I would remove the oil pan and check the oil pump for a plugged pick-up tube / screen or a bad oil pump. Don't run it like that more than you have to because it will cause internal damage. If you hear internal engine noise, it will take the bearing out.
Let me know what you find.
Saturday, January 24th, 2009 AT 4:03 PM
DRGONZO442
THank you for your help will let you know the outcome.
Thanks again
Saturday, January 24th, 2009 AT 9:08 PM
